Are the products you use safe for my pets?
The products our company uses Talstar Professional Insecticide, Tempo SC are both safe to use around pets and children. Only need to remove pets and children from area being treated until spray has dried, than it is completely safe for both pets or people. Spray dries very quickly, usually less than 30 minutes.
What are a few signs of a Pest Infestation?
Many pests are great at hiding away from people, which allows infestations to go on for far longer than we’d like. To catch an infestation as early as possible, you need to know what to look for. Spotting an infestation is the first step in controlling it.
Below are 5 common signs of a pest infestation:
- Unusual smells: Pests such as roaches and bed bugs produce a musty odor that you are sure to notice.
- Odd pet behavior: Are your dogs or cats fixated on certain areas for no reason? Are they barking or meowing uncontrollably? It might be that they can see, smell, or hear the pests lurking in your home.
- Property damage: Any instance of unexplained property damage – such as grease marks along walls, chewed houseplants or furniture, damaged food packaging, gnawed-on wires, missing insulation, or hollow wood – should be investigated right away.
- Droppings: If you come across small pellets or piles of pepper-like granules anywhere – including in cabinets or drawers, behind or underneath large appliances, or in the attic or basement – you may be looking at pest droppings.
- Nests: Rodents create nests using just about anything they can get their paws on, including insulation, trash, paper, leaves, and grass.
